Fuel System Questions
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
Hey guys,
I was going to go with a Bosch motorsports intank fuel pump when I was redoing my fuel system. Now that I wanted to order the pump...I lost the information on the specific part number and the source I was to order the pump from.
Does anyone know of another fuel pump that would be able to support 700hp, preferably intank.
James
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
If I was going for a 700hp pump, I would go sump tanked with an outboard fuel pump.
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
Contemplated the same thing. Not sure I want to have a protruding fuel peice on the bottom of my car.
I take the car road racing as well as drag racing - and the car with the new suspension is low.
What outboard fuel pumps are the most reliable for this amount of horsepower?
chevyeater
wastegate hose is pulled
Long Island, NY
Heh, what's up James? You getting senile? I still remember it is the 044 model you were after. Google said this place has a pile of them- http://www.jayracing.com/ . That is the highest capacity intank pump I know of and 700 rwhp would be pushing it.
The Aeromotives I know of (between me and Fernando we have about half a dozen running around now) are running well so far but, the Weldon is the best external pump. You are welcome to come have a look at mine whenever you'd like to get an idea of how I installed it, I'm not too concerned about ripping it off on a bump or anything.
-Brian
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
-Brian
Yes, getting senile...Brian, you are my savior. As always. I'm going to have to give you a call. I can't find a place to start installing everything and getting things ready for spring time, since when I parted from J&R. And I wont lie...probably need help with doing the fuel system.
figgie
Twin Cities, Minnesot-ah
walbros
wouldn't trust $1000 engine to a walbro, sure as hell wouldn't trust a $5000 engine to a walbro.
Weldon or even the Magnafuel Prostars SQ. Anything else is just a ticking time bomb.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Are you guys crazy?? Do you know how many 2jz motors out there run twin walbros with more money in the motor then 2 of our cars are worth.
suprarich
Guest
Nov 9, 2005
2,187
ohio
non that I have heard of. Why is a single walboro the standard when upgrading our own fuel. It is well known that one pump will flow enough for 500 hp and pump at 65 psi. I have owned over 10 supras since the 90's and everyone of them had a 255 lph walbro in them, and none of them have ever failed.
figgie
chevyeater said:
Do you know how many of them take a crap? :aigo:
agreed
that is why most guys actually run Denso and not Dalbro ;) Speak to Ken Henderson about what he thinks of the walbro. I personally can not use them thanks to ethanol but even if i could i wouldn't.
figgie
it is not the standard. Only reason it is the "goto" pump is because it is CHEAP. PERIOD.
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
Agreed. When I first started modifiying Supras we were using the walbro because it was cheap and easy. Now that there are other options out there - it is better to get quality parts rather than what's cheap and widely used.
chevyeater
Long Island, NY
Well, I've seen 4 of them die so far and heard of several more, just from the local Supra owners here on the Island. Now you've heard too. :)
James, LMK if you'd like to swing by or something.
