Fuel System 87 NA
salomon68
welkin
Feb 5, 2007
91
Knoxville
I have a fuel problem with my car and I need some more advice. The number 2 cylinder injector is leaking fuel between it and the fuel rail, and the number 1 injector is bad (reading 12 ohms). First, where is a good place to get stock injectors? (or better ones for the same price maybe). Second, should I just go ahead and replace all 6 injectors since they are the original from 1987?
One more thing, When I was taking off the intake manifold to get to the injectors, I noticed that a lot of those plastic electrical connectors are cracking and breaking. Can I get another ECU harness somewhere?
8,897
The ECU harness is costly. Besides the dealer, I don't know where you get another.
They can always be repaired with the proper repair kit.
There is an O-ring on the top and bottom of the injector, it is leaking. If you try this yourself, have a buddy that knows what he is doing. Gasoline=boom. Changing them isn't that hard. And you don't need to do all of them.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
You could get a set of turbo 440 cc if u want. Used ones are for around 30-40, aint that bad for a better upgrade. Or go with used 360cc (i think) from NA. They're not that much, members sell them on here all the time.
salomon68
welkin
Feb 5, 2007
91
Knoxville
when you say a "proper repair kit", what exactly are you refering too? where can you get this? also, where is a good place to get injectors?
akito
Jul 31, 2006
1,568
Springfield/Va
SUPRAMANIA!!! This is where can buy injectors for that price. Or ebay. they are pretty much the same price. Go to PART FOR SALE section. If u cant find any make a thread in WANT TO BUY section for the same injectors or turbo ones. SOME ONE will have em. Trust me
8,897
If he installs the 440's, he will be running rich. A terminal and connector repair kit has empty cases and male and female ends to install, along with the insulators.
akito
Jul 31, 2006
1,568
Springfield/Va
i know i could be wrong. But yea, or he could ask to buy stock non turbo injectors or use the set that u stated. I only know SO far, lol, hoped i could be helpful and not steer u into a different direction.
