Yea...I took it all off. I couldnt get at the bolt from underneath, neither could anyone I had over. So whats the problem with doing a bit of work? I learned some stuff, and got the damn thing off, and thats really all that matters to me.
Although I see you got what you need from your post I will post anyway.. You didn't need to take all of that stuff apart dude! :nono: The bolt is a pita but it WILL come off with patience. Fuel will dribble but very little.
i found that with the mani on, if you remove the brake master from the booster you can get accesse to the top bolt, and should be able to get the bottom bolt from below..
