So my car won't start after sitting for 1 day. Running fine before, '88 Turbo. It turns over fine and throws no codes. All the fuses seem to be good. I did the B+ to Fp jumper thing per:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=71
but my B+ is only reading 0.27V...
So I jumped the actual battery terminal to the Fp at the check connector and I heard a buzzing sound, then turned the key to 'on' and heard a whirring sound from the engine compartment, then cranked it...still wont fire.
Is the fuel pump bad?
I'd like to check the fuel relay too, but I can't find it! There's a bunch of relay looking pieces in the driver kick BEC, but no wiring diagram I could find.
Thanxz
Thanxz
