fuel problem
full_thr0ttle
84
Toronto
hey,
so i finally got my car started today after my rebuild, i had the car running for maybe 5 minutes or so, and i then shut it off to do a few things to it. when i went to start it back up, i had no fuel- the pump was doing nothing. I jumped the Fp and B+ in the diagnostic box, and still i get nothing from the fuel pump, it seems very odd because the car had just been running fine.
It is a brand new walbro pump, efi fuse is fine.. does anybody have any ideas as to what this problem could be?
kirk
full_thr0ttle
84
Toronto
yea there were no codes.. found the problem tho, turns out the wiring where the connector hooks up to the pump was shotty, played around with it and got it to fire up, thanks for the feedback tho
NewGen
799
Norwalk, IA
Go back to the tank and check to see if your gettin power at the plug. If your getting power drop the tank and check the ground on the pump.
