Fuel Pressure Regulator for 1jz?
ryan625
60
Lynnwood
Does anyone know if any SR20 parts may crossover for a 1jz?
My buddy has an extra full FPR kit for his SR20 that he has no need for and would sell me for dirt cheap but I don't know if it will bolt up to my 1j. I imagine that there is an FPR kit designated just for the 1jz but would it be possible to use this one?
Any advice is appreciated, and I'll eventually get a FPR even if this one won't work.
te72
Classifieds Moderator
6,602
WHYoming
If I understand them correctly, aftermarket FPR's are pretty universal, it is up to you to make them work. That said, Driftmotion has an Aeromotive setup for our cars, and if I remember correctly, it comes with a bracket to mount it too.
ryan625
60
Lynnwood
I will look into that then. I was told by the guy I bought my 1j from that it starts to run lean and hit an early rev limit at anything above 6psi...that seems lo but I am still learning about these motors.
I read elsewhere that a stock FPR is good for fueling until you get into higher hp situations. Ideally I would like to be able to turn up the boost for fun from time to time and run low psi for daily. I want bigger injectors and plumb in a wideband too at some point, as well as tuning etc. I am trying to do my homework before I start the whole process, any help is appreciated!
Turbo Habanero
4,229
Tucson,AZ
http://store.driftmotion.com/static/i-afprkit1jz.php
http://store.driftmotion.com/static/i-afprkit1jzwithoutregulator.php
The AFPR is universal what is not is the custom lines and mounting brackets
How would he know the car is running Lean if there is no wideband?
Here's the deal your Stock ECU has something called Fuel Cut (This is what is happening) Its a fail safe device to save your engine from over boosting it usaully does not kick in till higher boost levels (15-17psi) Unless there is something wrong with the operating system I.E boost leaks or Faulty Map sensor Ect..
This is a smart decision to protect your investment
In my opinion the stock AFPR should be upgraded when a larger fuel pump is installed it helps with tuning
Just be sure you understand what your doing and don't turn up the boost without a wideband.
A wideband should be your first mod for your car
All fine and dandy as long as you know the rest of the car is in good shape first Pumps/Hoses/Vac lines/Sensors ect..
ryan625
60
Lynnwood
That is a nice dissection of my post...lol
A wideband/turbo timer is first on my list for sure. After that it will be on to dressing up the car, inside and out, and under the hood.
I figure if I clean everything up and learn as much as I can while doing so I can find any worn parts and avoid spending money on something that could have been avoided.
I appreciate all the feedback, this reminds me of when I was learning to build diesels! Its kinda fun...
Edit: here is what I have been thinking of ordering for a sideband since it doubles as a timer when you shut the car off.http://www.innovatemotorsports.com/xcart/product.php?productid=16314&cat=0&page=1
te72
6,602
WHYoming
If you're having breakup problems over 6psi, I would suggest making sure your spark plugs are still somewhat clean and are gapped around .028 each. Never trust a 'pre-gapped' plug. ;)
