I found a post similar to the problem I'm having but it is in the 7M forum, and I am dealing with a 1JZ thus my reasoning for this thread. For reference purposes here is the link to the 7M issue:
http://www.supramania.com/forums/showthread.php?129750-Gas-leak&highlight=fuel+pressure+damper
So now for mine:
Upon attempting to start my car for the first time after finishing the 1J swap, fuel started spraying everywhere from underneath the fuel pressure damper. I removed the damper, and found there to be only one washer, on the damper side, which is the washer I've labeled as #1 in the photo. It looks to be aluminum. There was no washer on the opposite side of the banjo fitting.
After unsuccessful attempts of using non-specific copper crush washers obtained from NAPA, I picked up what Champion told me was required for the damper assembly, 2 washers, p/n's 23270B and 23807J, as called out in the 7M fuel component diagram below, and washers 3 and 2, respectively, in the photo above.
However, after looking at the fuel system components for the 1J, as outlined in the following diagram,
http://supramania.ru/wiring/Fig 22-11.pdf
it is clear to see that it calls out for two of only one type of washer that the 7M uses, the 23270B.
So my two issues of concern are as follows:
1) Is the #1 washer supposed to be on the damper, because it is not called out in the 1JZ or the 7M fuel system diagram.
2) How is one able to maintain alignment of the 23270B (#3) washers on the sealing surfaces if there is so much clearance between the FPD bolt and the ID of the washer?? (the motor is in the car so it is a very tight working environment), (see below):
Thanks for any and all words of wisdom.
So now for mine:
