fuel lines, oil presure sender, cooling fan questions questions questions
cpederson
117
wi
what the correct way to hook up the fuel lines in a 87 supra that has a 1jz?
will the 7m oil pressure sender fit it i dont have the 1jz ac compressor instaled?
can i just swap a 2jz water pump, fan, and fan clutch on to the 1jz?
thanks corey
