Fuel injector o-rings and rubber inserts & question about removing the timing pulleys
cartert
louisville
Has anyone used the fuel injector o-rings and rubber inserts from driftmotion? Do you recommend them? The ones from dm are significantly cheaper than toyota. Just want to confirm that they are of quality.
Also where can I find out what size/pitch bolts fit into the cam timing pulleys and the crankshaft timing pulley so that I can pull them?
Thanks for the help
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
What he said.
Plus, I think Driftmotion probably uses Toyota o-rings.
But regardless, I've never had an issue with any brand o-rings.
