Fuel hose or no? Anyone help please
hkstuned2
14
Central WI
Would anyone know where the hose that is circle goes to? When I got the car, it was connect to the boost pressure sensor. I took it off because I know that it is not suppose to go to the boost pressure sensor. I'm not sure where it can go because it also smells like it's a fuel hard line also. Any help would be appreciated.
hkstuned2
14
Central WI
Probably not in need than, if it's the EVAP? Does the EVAP hose go all the way to the rear end? I don't think right?
hkstuned2
14
Central WI
I will check again later when I get home from work, where the line goes to again and will let you guys know, if that will help pin out it.
hkstuned2
14
Central WI
Where should I connect it to than 3p141592654?
Bettie - I got the car how it is minus the blue hoses and no engine harness. I'm going to do everything to make it start first and then reroute or fix anything that needs to be fix.
Sep 17, 2013
757
San jose
maybe the EVAP hardline connects to the EVAP canister....
supranewbie
377
46°47.0'N 120°09.0'W
hkstuned2;2032825 said:
Might be the fuel tank breather tube. Not sure too but, what does it do or where should it be connected to?
Again; http://www.supracentral.com/foundation/tsrm/
Also, Google EVAP.
Try to learn the easy stuff, through the use of tools provided here. Flip through the manual, Google the names of parts and systems you don't understand, etc. It'll help you get (and understand) answers to the tricky stuff that's sure to come your way, if you last. If you're going to commit to owning a Supra you are well advised to learn it, whether you have deep pockets or not.
Sep 17, 2013
757
San jose
hkstuned2;2032833 said:
My car don't have the EVAP canister. Would I be able to get something aftermarket to replace it or should I get an OEM one?
depends on if you need to pass smog, they are good to have both for your own health and the planet's. OEM canisters should be easy to come by second hand. I know a lot of other toyota canisters work like the pickup's one often use due to it's smaller size.
hkstuned2
14
Central WI
3p141592654 - Thanks. I will be getting one soon than. One more thing, would that cause the car not to start?
atmperformance - We don't have emission in the city that I am in, but would like to at least have it.
f00g00 - Lol nice.
