Fuel Dampener Bypass
tissimo
Stock is boring :(
Melbourne, FL
Driftmotion sells a kit. I asked him about it since I was doing a custom setup, he said its a custom fitting he had made, so he worked with me to get what I needed.
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
That is what I thought. Well I will probably just end up cutting the fitting and flaring the end and getting an AN adapter. I just wanted to see if there was an easier way around that.
tissimo
Stock is boring :(
Melbourne, FL
Upgrade your fuel system and eliminate the hardline all together. :)
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
so has anyone had any problems with it since they removed theirs? i just removed mine but have not drove my car or anything at all yet
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
M14x1.5 I believe. I chucked the FPD in a box and switched to dual feed / center out back in 2002 but have only put about 10kmi on it since then.
A friend drilled through the FPD at the banjo 1-2 times and has put >100kmi on it since.
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
I think I have an extra fuel fitting that goes to a compression fitting. it was in my honda parts bin, pm me if you want it.
tissimo
Stock is boring :(
Melbourne, FL
The main reason to get rid of the fuel dampener is to eliminate the restrictions associated with it and the restrictive banjo fittings on it, to help maximize the fuel pumps capacity.
