fuel cut
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
Is fuel cut all electronic or will a clogged fuel filter also give me a code 34?
When spinning my turbo shaft by hand should it keep spinning after i let go or should it have just enough drag to keep it from spinning after i let go?
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Its an upper limit programmed into the ECM, limits the MAF sensor to a certian amount of flow.
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
i am stock. but i cant seem to find my freakin boost leak i found one hose tore but replaced it and checked and tighted the hose of the bottom of the turbo. but it still stalls bad. i m lost.
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
i put new hose clamps on it and thourghly inspected the hoses. this is going to drive insane. i have almost sold the car severel times. its never ran right since i bought it 3 years ago, and been broke down for most of it. but i can t seem to part with it. one other question could my inercooler be plugged. i was checking the tubes for it and pulled one off and a little bit of oil came out. ya MO.
Piratetip
1,179
70
MKE, WI
If you still have it stock the PVC routes into the intake, goes through the turbo, through the IC pipes and so on....
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
would that oil make the car cut out if it was in the ic? how freely should the impeller spin in turbo?should it keep spinning if i spin it by hand?
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
well i built my leak tester today and done from the coupler below the turbo to the tb. No leaks there. tomorrow ill check the pipe from the bottom of the turbo. but still only boosting 2 to 3 pounds this sucks.
has anybody put there own seals in there turbo?mine smokes pretty good.
N
NDBoost
Guest
87supraturbo19 said:
so does the oil coming from my pcv hoses into my intake hoses need to be fixed or is that normal? if not how do i go about fixing it?
its normal for a stock setup,
Are you throwing any codes?
