Frustrated with this stupid pipe! Where does it GO?!
1988SupraDreams
509
San Jose, CA
Where does it GO!? :1zhelp:
I've looked everywhere around the manifold, on the TB, under the manifold, in the front of the engine... It comes out of the IAC.. Someone please help.
On a lighter note, in spite of this stupid pipe, I started my 7MGTE swap today. Idled funky for a bit like I expected, but the surpising thing, is that it ACTUALLY STARTED. I underestimated my abilities. Only thing that went wrong was the o-rings on the PS pump. Started Leaking :icon_conf
Edit: Btw this pic was taken waay before I finished, so ignore the other misc crap that's disconnected.
johnathan1
Supra =
Aug 19, 2005
5,056
you can see it in that pic.
1988SupraDreams
509
San Jose, CA
Thanks guys, Yeah the mechanic who's letting me use his lot for the swap said that's what it was, he just couldnt find where it goes on the TB, nor could I.
Edit: I know it prolly doesnt make a diff, but its a JDM motor.
johnathan1
Supra =
Aug 19, 2005
5,056
Ok, I just checked...it goes into the SIDE of the throttle body, not the bottom...you can't see the fitting for it, because it is directly underneath the TPS...
You may have to take the throttle body off to get to it.
1988SupraDreams
509
San Jose, CA
I got a girl working on the car with me, and I have surgeon-esque percision with needle nose pliers. I think we can figure it out once I find the damn fitting, are there three? Btw you guys are way better than SF, I actually got multiple responses rather than having to bump it twice b4 I get just one.
1988SupraDreams
509
San Jose, CA
johnathan1 said:
There are two coolant fittings...one on the bottom, and one on the side under the TPS, the PCV fitting is on the top.
I got the 1 on the bottom going into the line that looked like it belonged there due to size of the pipe, theres one under the TPS... Ugh I feel like a retard THANKS A BUNCH GUYS! I know exactly where it is now. Ill post pics of my piece later!
Justin
Speakers?
Spokane, Wa
Here
A = From the coolant pipe that wraps around the block
B = Bottom of throttle body
C = Side of Throttle Body to ISC
D = Input to ISC
E = Output from ISC
F = Input to nipple on lower intake manifold
