uppers are zero, lowers have a little play, i think it is like .5-1mm.  I will look for sure in the morning, it is in the Front axle and suspension section.
								taid79;1136188 said:How about the plastic caps that go on the steering knuckle? I recently had a similar issue and it turned out to be these plastic caps on the knuckle.
I don't know what the correct name is but I put some grease on that bolt and the noise went away, so then when I looked at the parts catalog and noticed that I did not have these caps. part# is 45619-14020.
Good luck!
supradjza80;1136264 said:uppers are zero, lowers have a little play, i think it is like .5-1mm. I will look for sure in the morning, it is in the Front axle and suspension section.
theKnifeArtist;1136756 said:the steering stop caps? i have heater hose on them, it works great, as i stated before.
ok so whats left that could be clunking..
-tie rods
-rack bushings
-endlinks(?)
-strut mounts
any more info about bad strut mounts?
