Free Download – 1945 Air Force Game with Unlimited Gems
erin14667
181
1945 Air Force Cheats, MOD APK & Free Gems – Full 2025 Guide to Unlock Everything!​
If you're hooked on 1945 Air Force, you're not alone! With intense air battles, epic bosses, and dozens of aircraft to upgrade, it's one of the most addictive arcade shooters ever made. But let’s face it—grinding for gems, unlocking new planes, or trying to beat those insane levels can be frustrating without a little help.
Good news? You're about to get all the cheats, hacks, and tips you need—no ban, no survey, no root!
Get 1945 Air Force Free Gems & Cheats – Click Here
What is 1945 Air Force?​
1945 Air Force is a top-down arcade shooting game where you pilot historic warplanes, fight waves of enemies, and collect coins, gems, and modules. With PvP mode, tournaments, and hundreds of levels, it’s both competitive and addictively fun.
But the grind for gems, beers, modules, or premium planes can be a real pain… unless you know the hacks
How to Get Unlimited Gems in 1945 Air Force​
There are a few ways you can instantly boost your gem count in 1945 Air Force:
  1. Use the 1945 MOD APK – Download the latest modded version with:
    • ✅ Unlimited Gems
    • ✅ Unlimited Money
    • ✅ All Planes Unlocked
    • ✅ No Root Required
  2. Free Daily Rewards Hack – Tap hidden chests after level 5 and watch ads twice for double gems. Many players skip this.
  3. Merge Module Trick – Merge level 2 modules first to trigger gem drops every 3rd merge (secretly coded).
  4. No Ban Glitch – Avoid using mods during PvP. Use them only in campaign mode to stay under the radar.
✈️ Best Planes to Unlock in 1945 Air Force (2025 Meta)​
If you're trying to rank up faster, here are the top planes based on current stats:
PlaneTypeStrength
P-38 LightningBalancedFast rate of fire & power-up boosts
MiG-23 FloggerHeavyExcellent boss damage
F-22 RaptorPremiumPerfect for PvP domination
Su-37 TerminatorMergeUnlock via module merge (hidden bonus plane)
Pro Tip: Merging the same plane type twice in PvP gives a surprise critical boost every 7th wave!
1945 Air Force Cheats for iOS & Android​
Whether you're on Android or iOS, you can try these safe & working cheats:
  • Plane Swap Exploit: Start with a low-tier plane, then swap mid-battle for a higher one → instant damage boost.
  • Unlimited Beers Hack: Complete 3 daily quests, then immediately restart the app = beer counter glitch.
  • Cheat Code (Android): Tap your base 5 times, go to settings, then back → activates gem boost for next 2 rounds.
1945 Air Force Merge Guide & Module Tips​
Merging and upgrading modules is key for dominance. Here's how:
  • Combine Level 1+2 modules first for higher activation chance.
  • Avoid upgrading during PvP—it resets module power temporarily.
  • Use the "swap module" glitch: Equip a Level 2 module, quickly unequip and re-equip → stat boost bug activates.
How to Unlock All Planes in 1945 Air Force (No Pay Required)​
  1. Campaign Milestones – Every 20 levels = new plane unlocked.
  2. Merge Module Bonus – Merge modules during boss levels to unlock secret planes.
  3. MOD APK Shortcut – Instantly unlock every plane without spending a dime.
⚠️ Is It Safe to Use Cheats or MOD APKs?​
If you're using a safe version of the MOD APK from a trusted source, and avoid PvP battles, you're safe.
✅ Use in:
  • Campaign Mode
  • Offline Battles
  • Events (with caution)
❌ Don’t use in:
  • PvP Matchmaking
  • Leaderboards
Always enable airplane mode when using a cheat/mod to prevent sync issues or bans.
Download the 1945 Air Force MOD APK (July 2025)​
Looking for a safe link? Use this trusted option:
Download 1945 Air Force MOD APK – Unlimited Gems & All Planes
(No login. No surveys. Works globally.)
✅ Final Tips for 1945 Air Force Domination​
  • Claim daily rewards — double tap for bonuses.
  • Merge modules every 3 stages to trigger hidden loot drops.
  • Focus on planes with AoE skills—they dominate bosses.
  • Watch short ads strategically to double gem rewards.
Ready to Rule the Sky?​
Whether you're hunting for cheat codes, MOD APKs, merge tricks, or just want to unlock the best planes without spending real money, this is your ultimate shortcut to success.
Tap below to claim your reward now:
