FPR test questions
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi.I installed my Aeromotive FPR today and i jumped the FP and B+ pins on the diagnostic port and watched the needle jump up for 50+ psi. I pulled the jumper in fear of too much pressure before the needle stopped. I tried turning in the allen screw w/o the jumper the pressure dropped a tad then when i jump it again it would shoot up. How far should i turn in the allen screw to reach about 35psi? should i be adjusting it with the jumper in place?
-Steve
theDon
The Don
Med-City, USA (Rochester, MN)
Isn't the jumper just a way to get the pump going without starting the engine?
Top of the AFPR is a nut, you losen it then you can adjust the pressure up/down.
And to get the right base fuel pressure for your setup you'll need a wideband to know at least your idle A/F to start. But you need the car running then.
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
yes. ok. with the car in the on position, the engine NOT running, FP and B+ jumpered, vac hose disconnected, FPR screw all the way out i get 50 psi. I have the 12v mod done and an mk4 tt fuel pump. am i doing this wrong or something?
-Steve
theDon
The Don
Sounds fine to me, but you can turn it to whatever you want you know. 5psi, 10psi, 33psi etc whatever. For example I run like base FP of 40psi at idle but your setup may be totally different. Again having a wideband setup you will know your A/F at idle in order to set the right base pressure manually. And I would bet it's not going to be 50psi (but I could be wrong)
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
GrimJack said:
That seems awfully high to me... my adjustment range started much lower than that. I assume if you tighten the screw, the FP increases above 50?
yes, it increases way above 50 when i tighten. Remember, its at 50pssi when the screw is totally out and the engine off... mabye when i start it it will be different.
-steve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Battery's dead HAHA. Would this by any chance have to do with my 12v mod? I jumped the B+ and FP on the yellow plug (harness side) and the 2 pins on the resistor (harness side). Mabye i just left the dome light on.
-Steve
