FPR: Rising Rate or fixed?
alssupra
Boost Junky
Mar 4, 2008
Va
I was wondering which FPR I should use with my 7M. I just purched a 255LPH Walbro fuel pump, I am running the Lexus AFM/550cc combo with a larger turbo. I'm not going for anything over 400hp...Yet!?
CPT Furious
Now MAJ FURY!
KDOV
^^What he said. However, do NOT buy an adjustable rising rate regulator. I tried that once and you will not be able to turn it down enough for our cars. I had the go-go gadget smoke screen under WOT! :) The 1:1 is just fine.
figgie
Twin Cities, Minnesot-ah
CPT Furious;950644 said:
^^What he said. However, do NOT buy a adjustable rising rate regulator. I tried that once and you will not be able to turn it down enough for our cars. I had the go-go gadget smoke screen under WOT! :) Tthe 1:1 is just fine.
actually
the adjustable is just fine. The problem is specific to the aeromotive one. The by passs hole on the aluminum body is TINY. That needs to be drilled out.
CPT Furious
Now MAJ FURY!
KDOV
I can't remember the brand that I had, I ordered it from Cartech.net. The lowest it would go theoretically was 2:1, but even that was too much fuel pressure on my 550's.
