2 weeks ago During driving I noticed the engine really hesitates at all RPM's and starts to lean and temperatures went up. My fuel pressure oscillates between 30-34 . When I remove the vacuum hose at idle the pressure doesnt change. I thought the problem could be my AFPR or Walbro pump or the wiring. So I first checked for codes and none were present. Next I jumpered +B and FP per TSRM to run the pump direct. As soon as I did the fuel pressure went to 55 psi and stayed constant. I then removed the jumper at which point the fuel pressure went back to fluctuating 30-35ish. I concluded that my Fuel Pump Relay or Circuit Opening Relay must be bad.
Do you guys agree with this? The dealer sells the fuel pump relay and circuit opening relay for $81 and $110 respectively. Should I get new ones or get used ones? I still havent narrowed down which of the two relays it is.
