**FOR YOU GUYS CONCERNED ABOUT LAG**
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I had a conversation with Tissimo asking about timing and its purpose. After that I started to research and this is what I found. Thought I could share with you guys
The stock 1jz ECU has a very conservative timing map.
Follow me in this senerio:
Stock Twins, 1st gear
@ 1500rpm you feel the twins start to spool timing is aggressive to get them going
@2500rpm twin are @ full spool & ECU pull a bit of timing to smoot out power curve
3000-4000 rpm still full spool but ECU starts to add timing to hold up the power curve to about 5500
@ 5800-6200 Still full spool but twins can't supply enough air to keep up with the powerband
@6500 ECU has reached its peak in timing and can't add more timing otherwise it will start to get knock
6500-7200(redline) powerband steadily drops off ( in many cases it starts to drop off by 5800rpm)
NOW, SAME CAR BUT NOW IT'S SINGLE TURBO (GT4082,.68 A/R) STOCK ECU & SAFC.
@1500 car is bit peppy due to timing being somewhat aggressive to spool the twins, but there are non
@2800 I hear the single spooling but no power response is felt. The reason, the ECU's timing map is set to pull timing at this range because that's were the twins would be at full spool.
@3000-4000rpm, GT40 is screaming but still in lag mode, timing is absent therefore not enough psi from the single to create any powerband.
@4000-4200rpm, this is were the ECU adds timing to keep the powerband for the twins, therefore giving the GT40 the timing that it needs to spool and create some good power.
4200-7200rpm, seems like the timing is about leveled and relys on the knock sensor to pull timing if need be.
In Conclusion: The remedy to lag on a 1jz is mainly adjusting the timing to be in accordance with the turbo's characteristics. Your backhousing has something to do with it aswell. You can use an upgraded ECU (i.e. Mines, Blits, SARD,etc...) which normally has a more aggressive timing map that will assist in spooling a single turbo or a piggy-back such as an emanage blue or ultimate that will allow you to change the timing curve.
Here is my dyno sheet. If someone has a stock twin dyno sheet to compare, would help clarify my findings. Add or comment on this as you wish we can all benefit from this info and whoever else can add to this.
tissimo
Stock is boring :(
Melbourne, FL
I dont think its that so much, I'm sure it plays a role a little bit though. But the timing map is based on load and rpm. If the ecu sees 15 psi by 3000 its going to run lower timing, but I'm sure at 0 psi its still around where it should be. No doubt you can gain some lower end from adding a few degrees while it spools, but its not going to be a drastic difference. The 1j just is gutless without boost ;)
I also think the soarer ecu is more advanced in handling timing better then the jza70 ecu. The 1j seems to run stronger under a soarer ecu. (compairing stock vs stock ecus)
Spaniard
524
La pearla PR
This is a very nice write-up, I am glad to see someone other than me understands timing. haha. I can testify to this fact, I have a non-ball bearing GT35 on my car and thing looks just like the dyno graph above. The timing on the 1JZ is very conservative, I have a buddy in Japan that put a standalone on a BPU 1JZ Supra and just with very good tuning of A/F and timing, they gained 50rwhp! So there is a lot of power to be seen from good tuning with timing control. Imagine what type of power gains you will get if you were single turbo!
SirLoki
129
Fullerton
i have the same theory with the automatic aristo ecus for the 2jzgte..... even the automatic ecus from a 20v 4age from an ae111..... wondering if the ecus run a little more timing and fuel due to the car being heavier or running a different final drive gear. i have done a dyno comparison on my gen 4 supra and my corolla gts and found the auto ecus run fatter and overall have higher horsepower and torque outputs on the dyno.
Boostage
323
Florida
Dre the remedy for reducing lag is to open up the exhaust. timing isnt going to make a big difference in spool up. reducing back pressure is the major key in reducing lag.
My lag isn't as bad as Drew's. I hit boost at 3500rpm with my GT35r and it hits hard, but I thought it was because of my cams that made it lag up til then. I am ordering the Stinger Standalone from Aaron and I"m hoping that it helps me gain a little bit of power. I want to be able to adjust for my bigger injectors and also adjust my timing if need be. Should I be able to reach 500rwhp with my mods at about 23 psi on race gas? I made 446 at about 18-20 psi but I think my timing is off due to my SAFCII pulling almost 50% of fuel.
Sorry for the hijack Drew.
Model Year:
1991 (MKIII)
Engine:
1JZGTE (Turbo)
Transmission:
R154 (5 Speed)
Mods:
Garrett GT35r turbo
Sard 540 injectors (actually flowing 624cc)
Walbro 255 furel pump
Aeromotive FPR
Ported and Polished head
Crower 272 small core cams
Koyo Racing Radiator
Larger intercooler
2.5" aluminum pipes
Custom downpipe
New stage three clutch
3.5" exhaust w/ no cats
SAFCII
AVC-R
AEM wideband
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
How much bigger can I get...... ? YOu've seen my exhaust. If 4" can't do it I am screwed.
I'll show you the difference when we put in the blitz.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
Full boost by 3500psi?
I wouldn't say full boost. I'll go outside and drive it and let you know when I reach 17psi. I'll be right back............:evil2:
I'm back. As best I can tell by my AVC-R, I hit 1.4 bar at 4000 rpm, but it's going pretty fast so I could be off a little.
Boostage
323
Florida
When I had my built honda, on the dyno, with my AEM EMS we upped timing to 35*in vacuum to try spool quicker, but it didnt make the turbo spool faster, but made the car alot more responsive. running open downpipe however, decreased lag significantly, now while a 4" exhaust is big, adding a cutout at the downpipe, would help alot more. timing can get the cumbustion process started earlier, which does help a little, but it doesnt alow the motor to flow any more exhaust than before, freeing up the exhaust is alot more worthwhile.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
@ 2800rpm I am 2-4psi then it holds it until 4000.
@4200 I hit 20psi. So at about 36 or 3700, I am starting to climb really fast.
My point is that even if I am positive boost @ 2800 it will not start to move until rpm and timing come in to the equation which normally happens after 4k
I was told that my Crower cams would make my car real laggy and then hit like a train and that pretty much sums up how it feels. I thought that you might have aftermarket cams as well since our cars sound similar. What type of engine management are you running? Didn't you buy a standalone from Driftmotion?
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
Nope the scenerio on post #1 is my car.
Stock ECU with SAFC.
tissimo
Stock is boring :(
Melbourne, FL
paying with timing will increase it a little bit. A bigger exhaust works off of manifold pressure differences. If the exhaust manifold has 10 psi and the exhuast has 1 psi, itll flow more, if you're restrictive and have 5 psi then yea a bigger will help. But with a large 3" dp and the smalll flow from the engine at that low boost levels isn't going to make much pressure, so it doesn't spool it up fast. If anything a smaller runner manifold will increase spool more. Keep the velocitys up rathen then a the port dumping into the huge manifold. Of course it hurts flow and upper rpms itd be apparent (stock twins).
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Here's mine with stock ecu @ 12psi with bpu and walbro 255 pump. I'm in love with the twins as you can see :love:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
OT, but hero, what do you want for your afc?
on topic, the 4082 is a little bigger than a 35r, im hoping for spool similar to sh with a 61
