Okay so 7mge tach will work fine with 1j the difference is just frequency. You have to hook up the black wire from igniter which is IG- on the diag box and same on the tach.
So go take your tach out and on the screw hole where ig- signal enters the tach look for the first resistor once it hits the board. Should be a 30Kohm. Cut it off leaving a little of the leads. Then solder a small piece of wire in where the resistor was. I've verified against an safc2 and also dynojet and it's dead on all the way to 8krpm.
Put tach together and go rock out!
PS: this works with 2jz also.
