So here's my base maps for 1jz with stock everything and also with usdm550s. Both of these are tuned up to 18psi.
These are configured for my setup (sequential COP w/ stock igniter) and all stock sensors. For all you wasted spark guys you'll need to change the code config to work with what ever spark you have going on.
This is not a perfect set of tunes but they are safe as I drove around on them a lot. Make sure when the spark map is 0 deg a timing light will read 10 on the pulley. If it's anything else you'll be way off. Lastly, these are files to work with MSNS 029i. I've included the config file for megatune so you can open them. If you have a different firmware you should still be fine as long as it's newer.
Anyhow thanks for looking I hope these help someone
http://www.geocities.com/aphxero/1jz.zip
