Fog light Help!!!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Ok i have some after market fogs and im trying to wire them up with my parking lights... The fog light harness was cut to hell from previous owner:3d_frown:!
I want them to be on when ever the parking lights are on so i spliced them like this...
I originally had one light go to one side and the other the same way and they worked for a day but one was dimmer than the other, so i came up with this approach... The problem is it blows my fuse when i try em... even a 30amp:aigo:!
Do i need a relay or what should i do???
No wires are crossed, everything is connected legit...
:1zhelp:
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Damn!!! That wont help me that if for the stock lights and harness... I dont have the stuff for that!!! Is there any way my ghetto set up will work or any corrections i can do to make it work????
tissimo
Stock is boring :(
Melbourne, FL
You have the stock foglight wires right? then connect your aftermarket foglights to the stock wires and do the rewire
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Nope... I dont have the stock wires... That is why i need help to splice em into something else....
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
hottscennessey;912266 said:
two options:
use relays (don't forget fuses).
More info please... Im a retard when it comes to electricity... how would i hook the relay up and where could i get one or how ever many i need???
Thank You!!!
