Okay I just swapped a 7MGE into my 84 Toyota pickup. Sounds weird but so far the engine is amazing I just have a few little bugs to work out. If you can help me out on any little question it would be greatly appreciated.
Background: I pulled it from an 89 that had overheated with a blown head gasket. I took it to a machine shop and he replaced the head gasket, and checked the valves. He said they didn't leak for about 4 minutes before he saw a drop of solvent leak through the valves so he said they should be good. He also did a quick glance at the bottom end. Well it has been running for about 2000 miles now. Also while i was trying to start the engine for the first time... :nono: I put the distributor in 180 off. Could that have affected anything below?
1. The engine has run well since i put it in. As i get going in the morning it likes to burn a little oil. Is that normal or where should I look? When i get going it doesn’t seem to put out any blue smoke, but the engine has been burning oil. Any idea's where to start
2. Sometimes when i start the bugger it coughs and then dies? Is that oil getting into a cylinder and causing it to not fire. It sounds horrible. Like a loud bad cough. It usually will start up after.
3. The vacuum small pipe out the back of the intake manifold, there is a line that goes to the cruise control. Should i just put a cap over that? Right now its open. Should it be going to something important. (I don't have cruise control.)
4. It sounds like there is a valve ticking at about 2000 to 3000 RPM's. How do i go about adjusting them. (sorry use to the 22r) A quick overview would be nice or a link to another forum that explains it, could work.
Anyways hope you guys can help me get my engine running smooth...
