Firewall & wires please help
huntin5L
Niles, IL
Sorry for starting a new thread need assistance asap. Getting dark here and i need my car tomorrow. Do i need to drill into the firewall to get the wires and hose to my EBC. Somebody told me that there is an opening under the the clutch master cylinder i only found an open on the fender and it doesn't look like im getting it through there cause there is nowhere for it to come out.
huntin5L
Niles, IL
yes i have cruise, but it goes through that whole in the fender. There is no opening underneath the driver site dash where it come out of.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
well the only holes i can see coming thru the firewall is the cruise control cable hole and clutch cylinder... looks like ur gonna have to drill
the only hole under the clutch is for the auto trannie speedo cable... that must be what they're talkin bout... so if ur auto that'll be why theres no hole probly heh
good luck with it
Justin
Speakers?
Spokane, Wa
see where the boost wire disappears? That's where I drilled a hole thru my firewall using a step-bit, or a uni-bit, calll it what you will..
