Looking for the diameter of the 7M Engine harness hole and Speedo Cable hole. Need to order some block-off grommets and my car is 1000km south from me.
If anyone has the time to do this, I'd really appreciate it.
1JZ swap, yes. I already have the harness run through a hole I cut below the speedo cable and will be using the 7M harness hole and speedo cable hole (VSS sensor for custom dash) for routing sensor wires for the other gauges.
