Finding TDC
canadian
Newbie
May 16, 2006
366
Victoria BC
Is there anyway to from TDC on the comp. stroke with the timing cover on?
I have the camshaft timing sprockets lined up with the mark, and have the crankshaft pulleys mark at 0*. BUT stupidly, I am not sure if my #1 piston is at TDC. Is there a way to test this, or should I pull off the timing cover and re-do it?
In the TSRM for setting TDC they say rotate counterclockwise 120* after the camshaft lobe is in the right position. then rotate it clockwise 10-40* until the timing cover and crankshaft pulley mark are aligned.
What mark on the timing cover do I align it to? The 0, 5, 10 or 15 degree mark?
Thanks
EDIT:
This is on an engine that the timing belt was already removed and the crankshaft/camshafts were moved, now I am putting on a belt and trying to find TDC from scratch...
spoolint78
Representing T.O
T.O
pull out the sparkplug in the # 1 cylinder, and check and see if its at the top.
everything should be at 0
Mr. Y
80 miles away from Kremlin
canadian said:
Which other piston is at the top of the stroke when the first piston is at the top too?
BTW, it doesn't matter where timing belt now. Just set crank at 0*, then align camshafts with marks up and put timing belt on. After that check your ignition timing... (using timing light)
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
...while making sure that piston #1 (the front one) is all the way up. BTW, a good way of telling where the piston is is to insert a screw driver into the spark plug opening so that it stands on top of the piston; just make sure the screwdriver doesn't slip to the side and bind.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
On one of my other cars, don't know about the supra, but TDC on the piston is actually a tad bit off compared to TDC according to the crank pulley marks.
I'd be curious to see if yo uset it a 0* TDC and move it slightly either way, to see if a screw driver on top of th piston will go up a tad bit more before falling back down....
I use a piece of Vaccum hose just in case so it can't mark the piston.
canadian
Newbie
May 16, 2006
366
Victoria BC
So I don't have to use the TSRM way of setting TDC? I can just align the 2 camshaft marks and 1 crankshaft marks, making sure 1st piston is at TDC?
Yes both cams on the base circle with their marks up and the crank at true TDC.
A lot of times the outer ring has slipped on the stock damper giving a false TDC if you go by the mark so it's a good idea to confirm it using some hose.
If it has slipped NOW is a good time to replace the damper before it seperates and does damage.
extendor
9
Devon
I dont think you can beat a dial gauge. I have seen timing marks quite a way off and in that case you need to make a new mark on the pulley that you can trust.
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Sure the previous owner didn't adjust the belt for brake in? Some cars require that.
canadian
Newbie
May 16, 2006
366
Victoria BC
jetjock said:
I'm a believer in learning about something before I do it. Theory and fundamentals first. Makes things go a lot smoother.
I agree, I try to learn as much as I can about something before I start...sometimes it doesn't work for me though.
Thanks
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
figgie said:
A twig is my friend.
I would be afraid to stick any metal screwdriver down the spark plug hole. Gouge the hell out of the piston top.
oops! :biglaugh:
canadian
Newbie
May 16, 2006
366
Victoria BC
Well I guess I got lucky-I measured with a piece of cardboard lol I couldn't find a long enough piece of pipe- the 1st piston was up significantly higher than the other ones! So I guess I did things right for a change :naughty:
