Finally sumped my tank
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
History: in 2003 I had an aermotive A1000 mounted above my Diff, over the years gravity and sediments in the fuel tank finally killed it. I also did not have a pre-filter, I only had a post 100-micron filter.
Now I have a pre 10 micron and a post micron filter, here are the pics. The 100-micron is not pictured, it's directly under the driver seat (underneath the car of course)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i welded bracket n my gas take so that way it would not make as much noise and well and be hold no noise no vibes but looks goo thou
Apr 6, 2005
339
Alpharetta, GA
Hey Manny.
Is there any brace attached to that welded plate? if not, then those welds will eventually fracture due to weight of the pump and vibration induced fatigue. You may not drive your car often for this to be an impending problem, but it's a certain eventuality.
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
i just did mine identically to your setup except im running a aeromotive eliminator.. i also used some rubber washers and made little supports to help hold the weight. but yes going over bumps and that whole deal. yours will eventually fall off.
any body else rocking a sumped stock tank with inline fuel pumps?
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
BlackDevilSupra;1594738 said:
Hey Manny.
That is a possibility. The welds seem very strong but I will ask the shop.
Thanks for the compliments guys.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
here is mine
i going to be changing my fuel line around thou as the return
reson why i did this is well i can take the swap bar off pretty easy/aline my car and the gas tank keep the vibes/sound low
