ffim questions
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
I am in the processof upgrading my '88T and I'm wanting a FFIM. What connectors/sensors will be needed to hook up to it if I'm running Maftpro with s/d? Buddy is building me one, so I just want to make sure I've got all the required fitting sites drilled/tapped.
dbsupra90
toonar
indiucky
vac fittings for sure. thats all that has to be there.
the rest is up to you. egr, cold start injector, and the isc are the optional parts.
egr= emission inspection?
cold start = may have to crank a little longer in cold weather
isc = will have to bump up idle speed and let the car warm up before you drive it.
