Im Just about to finish my build of:
7m-GTE:
Toga Bearings
Fully balanced
Shot peend rods
Knife edged crank
JE +.40 pistons
Stage 2 cams (272)
New valves etc
Ajustable cam gears
Unordox Pulley
Solid mounts
EGR Removed
Fidanza Flywheel
6puck clutch
I want to hit 500wrhp....
Would you agree with a HKS 2.0mm Bead headgasket?
Also are the bolt on intercoolers going to be any good? or do I need to go FMIC with a FFIM?
Many Thanks for your help in advance!
Regards
Adam
7m-GTE:
Toga Bearings
Fully balanced
Shot peend rods
Knife edged crank
JE +.40 pistons
Stage 2 cams (272)
New valves etc
Ajustable cam gears
Unordox Pulley
Solid mounts
EGR Removed
Fidanza Flywheel
6puck clutch
Regards
Adam
