Few question during 1JZ swap
wht95scort
NJ
I've been doing a 1Jz swap in my friends supra and I'm not sure about a few things.
1. How does everyone hook up the main fuel feed? (The car is a 7M non turbo car orig)
2.The clutch slave cylinder on the w58 had a rubber line to it. The R154 is hard line. Do you just make a new line?
3. The aluim tubes that connect the two turbos(pressure side.) were missing the metal gaskets. Can you use a thin coat or sealer? Or can you buy these gaskets?
4. I bought the 2JZ throttle cable and it still is short? Any alternatives?
Thanks guys or any input.
mkiiichip
1,434
WI
1. The stock turbo soft line.
2. The R154 uses a hard line and a soft line. The soft line bridges the gap between the body and transmission.
3. Dont know
4. There is info about a camry throttle cable that works better. But i have not tried it, so im not sure exactly which one. A search pulls up a few different results so IDK.
http://www.supramania.com/forums/sh...ap-and-parts&p=1019217&viewfull=1#post1019217
http://www.supramania.com/forums/sh...swap-and-parts&p=489442&viewfull=1#post489442
http://www.supramania.com/forums/sh...-inside&p=1643381&highlight=camry#post1643381
r45marsh
Old MotorHead
Sep 22, 2007
57
Huntsville,Alabama
92-95 camry 4cylinder, cable from pedal to black box in the engine bay(not the one from black box to throttle body). This is what I uses, fits right!
