Feul Gauge
ians13
537
Jacksonville, fl
Hello all, am having a problem with my fuel gauge and was wondering if there was some easy fix out there. well my guess is the sending unit in the tank is shot because my gaugemoves very little and now it rest below the E mark so i don't know when my gas is low the light does go on and off so am guessing the light has a diffrent sender.
if i do have to remove the fuel pump/sending unit does the tank have to be removed i know you can access the connectors from in the hatch.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Yes the light is off of a different sensor, but is on the same assembly as the gauge sender. No you do not have to drop the tank to take the sender out. The sending unit is the item that is attached to the tank under the access panel in the hatch.
I wish toyota was smart enough to make an access panel for the pump hanger assembly also.:3d_frown:
ians13
537
Jacksonville, fl
i hear that, but i'll remove my sender and see if i can fix it .
