FCO or Detonation??
ihiryu
209
TX
Hi guys, I'm still a noob still. Currently I just got my 2jz-get running with 7m electronics. I have HKS MHG, ARP head studs, and an ebay turbo kit. I've got everything running so far, and I'm waiting on my boost gauge (stock one doesn't work).
I ran into a few issues with the knock sensors and stuff but I've gotten them taken care of now. So finally I take her down the road (with no codes) and went WOT. At around 4500 she'll spit and sputter and flash the CEL. I'll let off, and the CEL will go away.
If I ease her into the 4500-5500 and go WOT she'll spit and sputter and the CEL will come on.
Is this fuel cut? Or do you think it's worse; detenation? Hopefully my Zeitronix still works and I'll wire that up temporary just to see what kind of AFR's i'm seeing. Fuel wise it's all stock 7m-gte, with the exception of an AFPR (currently set at fifty just to be on the safe side).
On the fuel side; my walboro should be in tomorrow (hopefully) I'm still debating on safc or emanage blue, (I can get both, but the blue doesn't have the support tool), and I have a Lexus AFM. I don't have the cash for 550's yet, so AFM will wait (I might just stick it on and screw the screw all the way in, can anyone confirm this?).
Also can someone chime in on the "J pipe" bypass? I've searched on it today for a bit (was more worried on FCO or detenation) on it, but it's still a bit on the hazy side to say the least.
Sorry got side track; what do you guys think? Does it sound like fuel cut? If it is, what should I do? No matter what I do on fuel (turn the AFPR up; put the piggyback on) I should still have FC right? It's an issue with the maf correct?
Is there a way to run just the lexus AFM (and hopefully my wide band o2 still works, guess I'll find out tomorrow) without injectors to see if it's just fuel cut? I read somewhere about turning the screw on the lexus AFM all the way in. I know about the risk of doing this without injectors, but I'll have my fuel pump and my zeitronix, I just want confirmation that it is FCO. So if it isn't FCO I can continue to diagnosis my car.
Many thanks guys
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
about the lex afm, screwing that bolt in the afm out will cause your engine to run lean or leaner than it already would be without injectors
if you think about it, the wider that opening is, the more unmetered air passes through and thus per unit of air combines with less fuel injected
also, see what codes you come up with
if you dont have an OBD reader, use the tsrm
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
grimreaper
2,180
Dallas
sounds like fuel cut. check the code that will tell you.
stock fuel= stock turbo
this 2j is running on the 7m ecu?
ihiryu
209
TX
again, I can't cause the CEL doesn't stay on. Yeah I'm using 7m electronics (ecu CPS coils). I pretty followed dok33's build.
ihiryu
209
TX
I have code; 34, 42, and 51.
34 is turbo charger pressure abnormal
42 is speed sensor circuit
51 I shouldn't worry about right?
ihiryu
209
TX
after some searching it seems code 34 is the telltale sign of FCO. Can someone explain to me about why boost leaks matter exactly?
So what can I do about FCO besides the lex afm and 550cc? When I search about fuel cut off, that's what I get or a FCD. I can't turn the boost down cause of the wastegate....
Also should I worry about the code 42? Does the ECU use the speedometer for a way to calculate load?
