Fan Clutch
rrkpitt15
14
Mercer, Pa
How do you know if the fan clutch is bad???? I have a very loud squeek when i start my car but after acouple seconds it goes away....when it goes away the fan speeds up??? If the car isnt cold, it really doesnt squeek either...
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
with the car off, grab and spin the fan, if it spins more then 2 revolutions, its bad.
normal is about 1 spin before it stops.
iwannadie
981
gilbert, az
x87SUPRA87x said:
thats too much play in the belt
Depends how hard you push it, If your really forcing it then you can get it to far. I thought it shouldnt be that much pressure to test the tension in the belt?
rrkpitt15
14
Mercer, Pa
i just tighten the belt to see if thats it now i have to wait until everything cools off to really see if that was it...thanks everyone
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
When ever you warm up you're car then let it sit for 5-10 min do you hear the fan clutch push a lot of air for about 1/2 a min? Other then that sounds like a loose or warn/dry belt.
