Factory Sunroof help
suprajim54
119
Dallas, Texas
I have a 92 with a siezed power sliding sunroof. I hit the button and it lifts up about 1/4" and stops. The motor will keep running, but there must be an issue with the tracks. I've tried turning the manual screw, but it won't budge. I've taken the headliner out, but still can't see any tracks or cables for me to adjust/fix. Has anyone ever taken theirs apart? Anyone have a 91 or 92 TSRM and does it show any info about the sunroof? Thanks in advance
suprajim54
119
Dallas, Texas
I think it is pretty much the same with just a few differences (location of the motor). I finally figured out that the motor needs to be removed to be able to manually open the roof using the slotted screw. I'll see if the adjustments are similar and report back. Thanks bio!!!
Pull the motor off and see if the gears are stripped. Buddies was and he found a gear that worked in the junk yards off another ford or something.
