External Waste Gate Question....
LEGNA
80
CT
I have ball bearing water cooled 62-1 68 trim and i really dont want to use the stock waste gate...I dont even know if it will work but my question is..i think im going to purchase a Tial 44mill polished but dont know if its the right size or what size spring to get the waste gate comes with a v-band flange any pics on where is the best place to install the waste gate... is there a better waste gate!!!!..
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
44 is to big 40 will be better
around 10 psi is good one to start with
you will have to make an adptor to mate that bad boy up just put the gate in the adptor
and asfor the gate 2 ways
weld the door or just leav it un hooked as in the vac line
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Need a little more info.
Are you on stock mani?
Is the turbo currently internally gated?
Give us some more info and we'd be glad to help.
LEGNA
80
CT
Yes stock mani and currently internally gated i was told to weld it to the mani but to keep clearence in mind
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
You'll need a spacer with a WG section welded to it.
You may be able to get away with just removing the vacuum source to the actuator of your current internal gate... it should keep it closed due to the spring pressure in the actuator.
As for what size wg to run is COMPLETELY dependent on boost pressure you wish to run.
I run a 50mm WG since I like better regulation control at LOW boost... if I were to run 15+ psi, a smaller diameter WG would be ideal.
LEGNA
80
CT
Do you have pics...and i could weld it shut its not on the car yet getting all the info i can before i buy it..15psi-18.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
http://supraforums.com/forum/showthread.php?t=361669&highlight=manifold+adaptor
images
I cannot get any larger pics, since MAXX has since gone under.
