Experienced MKIII teardown...
rcboricua07
7M powered
May 20, 2007
81
Massachusetts
I wanted to ask if i can eliminate all emission related components without affecting the cars performance and also how to go about doin it if theres something i have to do besides taking it all out such as maybe cappin somethin off ...also I was wonderin how much power i can make safely while using a stock composit headgasket.. i would really appreciate the help thanks
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
uhm, why would you want to rid of ALL the emissions components?
Asking how much power you can make safely from a stock headgasket is like asking someone to pick the number your thinking of from 1 to 1000000; there any many many factors most of which unseen. Most people can trhow 10PSI at a stocker and get away with it for awhile (will not last), some have stock boost and blow it to bits. Depends on the cars past mostly.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
i would edit my previous post but there constantly is an error:
Tthrowing Stock cats you can gain some good power from but things like EGR are ultimately more beneficial. You can rid the charcoal can but then you have to setup a good, efficient, and SAFE system of venting the gas tank
crazysupra2JZ
740
Georgia
my engine had no emmisions stuff on it. the egr was blocked off at both ends of the intake manifold. i had no charcol canister and my cat was gutted out, which i didn't know when i bought the car. car ran great though. never really had a problem with it.. egr wise
rcboricua07
7M powered
May 20, 2007
81
Massachusetts
I plan on gettin a wideband o2 sensor till then im going to keep the stock o2 sensor..im just wonderin how this will affect the car cause alot of it has vacuum running to it i idk how to eliminate that stuff properly...
crazysupra2JZ
740
Georgia
the ecu kinda needs the factory 02 sensor. just having a wideband on there will do nothing for the car. it's just for you to monitor to make sure you aren't gonna melt a piston.
if the engine runs great why would you start taking stuff off of it?
:rofl: @ JJ
EGR is needed as the ECU is tuned for it, and it doesn't hurt in any way that I've seen. Charcoal canister serves a purpose, if you're vain and want to remove the "ugly" canister, just relocate it with a smaller JDM one. The cat in the downpipe usually clogs and kills performance, getting rid of it won't hurt emmissions that much (I still pass fine with a stock main cat). Going to a high flow main cat will help as well, but only if you have the flow in the rest of the system.
A stock HG will hold a lot, but it's less durable and won't withstand detonation at all. Like most things, it's all in the tuning...
