Exhaust wrap?
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
I'm having problems with underhood temps going high enough that my new wiring harness is melting! It was suggested to me that I wrap the exhaust manifold and downpipe with a DEI exhaust wrap, and I was planning on it until a buddy of mine said that keeping all that heat in would cause my manifold to crack...
What do yo guys think? I've seen a lot of guys around here with wrapped manifolds? Any other suggestions?
Thanks!
Collin
tte
Breaking In - in progress
Northern California
Thanks!
Collin
I have had my exhaust manifold ceramic coated and am thinking of buying a
turbo heat shield.
This might help you.
http://www.heatshieldproducts.com/thermal_barrier_index.php
Cheers,
Roy
OneJoeZee
Retired Post Whore
aboard the Argama
The exhaust wrap that was on my downpipes when I got my kit didn't seem to help much at all. But then again, the wrap job was not very good or complete. It was a little toasty under the hood on the turbo side... Although not melting my harness.
I'm having ceramic coating done to the turbine housings downpipes and manifolds right now. Hope it helps drop the temps. I'll let you know how it goes. Might be a good option for you too. I don't plan to re-wrap the downpipes again though.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
turbo heat shield.
Cheers,
Roy
Do you have any before and after experience with the ceramic coated manifold? Did coating it really make a big difference with underhood temps? I was told that wrapping it works much better. I've had ceramic coated headers on non-turbo cars, and they didn't really hold in much heat over uncoated. Coated looks much better, but I'm looking for functionality.
Collin
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
In reference to DEI product, if you use the Hi-Temp Silicone Coating first, then coat with the DEI Wrap, it works very well. :)
tte
Northern California
Collin
Well for my car I noticed my underhood temps were lower. Ceramic coated exhuast manifold with the stock heat shields worked for me.
I think for the turbo its best to use a heat shield bag. It holds in the heat much better. I have to buy that and I plan to also route incoming cold air from the front via aluminum flexible ducting to the turbo area or I might place a vent in the hood above the turbo area.
Cheers,
Roy
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
supramike7m said:
thats what i did with my old setup. coated, then wraped, then coated again. worked well like that.
That's what I was thinking I would do. So nobody has had a problem with manifolds cracking from holding the extra heat in?
Collin
tte
Northern California
Also you will need to find out why the temp is so high that it melts the wiring.
I think alot of ppl are here have high hp cars and the heat does not melt their wiring.
How high is your exhaust temps?
Cheers,
Roy
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
Cheers,
Roy
I don't have an EGT gauge, but the problem may be due to the fact that I am stull running a stock exhaust, and it's very restrictive compared to the rest of my setup. It hasn't started to melt the wiring yet as much as the split loom around it is melting a bit, and I want to do something about it before it gets worse.
Collin
OneJoeZee
Retired Post Whore
aboard the Argama
Collin
That would be a good guess.
That stock crush bent 2 1/4 or 2.5(whatever it is) isn't doing a damn thing for you but causing a huge bottleneck and probably tons of backpressure.
tte
Northern California
The best thing to do is fix the cause of the extreme heat and then worry about the wrapping. If you are able to do an exhaust upgrade, then it would be advisable to do it.
I'd also check the timing too.
Cheers,
Roy
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
I think the car is going to be parked again for the winter. I'm leaving the insurance on it this time since the difference is only $186, just in case I need to move it somewhere. Before I consider it road worthy it needs a coolant leak fixed thanks to the excessive heat killing another bypass cap, a full 3" exhaust, a new acc. belt, and acc. belt tensioner... The cost of all that isn't too bad, but it's more than I have right now. :( I hate being a college student, and I'm really happy I didn't try to make this thing my daily driver. lol 88 N/A w/ working A/C FTW!
Collin
OneJoeZee
Retired Post Whore
aboard the Argama
Collin
I just looped the unused water nipples together. Two caps busted on me in less than a day. Looped them together instead of capping, problem gone.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
The one I'm having trouble with this time is on the bypass pipe on the pass. side right next to the downpipe. There isn't another one to connect it to. :(
Collin
OneJoeZee
Retired Post Whore
aboard the Argama
Collin
Wait, the one coming off the hard water line around the back of the head right?
I looped it together with the one for the 1st turbo.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
or he could have an exhaust leak between the manifold/ turbo, or turbo/ downpipe. letting alot of exhaust straight out to your engine bay. that would make sense considering its getting hot enough to melt your harness. damn thats hot :icon_evil
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
I'm thinking the split loom that I used on the harness may be of shitty quality, but it's still a little too warm for my liking.
No exhaust leaks except for downpipe > cat because I didn't put a gasket in there as I'll be pulling it off in favor of a 3" soon.
Collin
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
The two outlets are on the water neck and then one of the returns is on the water pump and the other is on the hard bypass at the back of the head. I'd have to run a line past the turbo and all the HOT exhaust parts to another nipple. I've thought about it, but I have no idea how I'd keep it off the downpipe and manifold.
Collin
