Exhaust Studs
Intothenight19
Crissaegrim
Feb 23, 2006
221
Pa
Does ARP make exhaust studs for our manifolds? I believe its a 14mm stud, Im just in need of locating some because my car as a nasty exhaust leak at the manifold and three of the nuts were loose, and one stud just pulled right the hell out..lol...Thanks all..
staticpat
Supra Chair!
Birmingham, AL
I believe Aaron at driftmotion sells a helicoil kit to replace with stock studs. I fixed mine before these were available and just drilled/tapped holes for bigger studs. Aluminum is fun.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Use the Toyota gasket...it's was revised a while ago. It's a multi-layer steel type, much better than what you will get aftermarket.
