O.k. I blew the HG. I had another motor sitting for similar occasion. After the swap i heard a blow throug the exhaust manifold. Ok, i took it off, the gasket was shot. Also, i compared the manifold from my old engine with the one on the new(used, but lets call it new) engine. My old one was in better shape. So, i used it with a new gasket and it still blows. I took it of again and started to measure things. Turned out that the old manifold is curved in the middle. You can put a ruller on it and it see saw's. The new one is just opposite. It dips in the middle. Ok, you can machine one or another, but the question is this. if the two manifolds differ that much are the heads also curved inwords or outwords, because you can't swap manifolds from them? Is that possible?
