Exhaust gasket maker/sheets?
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Do they make metal exhaust gasket sheets? I am in the process of cleaning/rebuilding my Greddy wastegate and can't get the gaskets anymore from Greddy so I need to make a few odd shape square gaskets. Any ideas on where I can get exhaust gasket maker or sheets?
grimreaper
2,180
Dallas
orillies (sp?) has the sheets for under $10. I used this in a pinch for my dp to catback flange and havent had it leak yet! (7-8months, 4-5,000 miles)
Coat it evenly with the copper spray or exhaust gasket maker (usually red).
as far as it holding up to the waste gate temps at the manifold... not a clue. cheap enough to try though.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
A few odd square shaped gaskets with small diameter holes in the center, and one butterfly shaped square gasket with a the same diameter center.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Is it like metal material? I've seen the regular sheets.
I bought a sheet from eBay a while back. I think it was called Ford gasket maker or something like that. I'll try to find it for you. I think I paid a good bit for it though. It is about one foot by three feet of gasket material.
grimreaper
2,180
Dallas
crap i totally blanked on the "metal" part. nope im speaking of the paper stuff.
id imagine a sheet of the graphite/ metal gaskets that will with stand the egt's of the mani will cost a bit more...
grimreaper;1428842 said:
link = no dice^
Nghty89;1428857 said:
Bad link, it no longer shows the item :p
Must have to be logged into my eBay because it works for me. I'll get you another link, cause that's just how I roll.............:biglaugh:
I'd have to see the gaskets, but if they're what i think they are you're going to have to hunt down someone that can make them...
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Poodles, that's what I was afraid of..hopefully I can make some myself.
Suprahero, do you think that would stand up to the temperatures of an external wastegate? (It's the gaskets between the bases)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I hate to say it, but check if anyone knocked off the greddy wastegates. Chances are that the gaskets will be the same. I know with my XSpower gate, I can run any HKS part in it (spring, diaphragm, etc.
I don't know how hot it will withstand but I have mine between the flange and the turbo and it's doing great. It sure beats the piss out of an exhaust leak. I was tired of my car sounding like a log truck.
