ET match my MPH?
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
So i went to the track and i got about 5 runs in.
All my runs were consistant and i was surprised!
Never got worse than a 2.2 60ft and never worse than a 13.2 in the 1/4 and was always at 110mph with the exception of one 109.
So here is my best run, i was just wondering what you all thought of this and if the MPH matches pretty good with the ET.
Thanks
60ft - 2.0951
330ft - 5.6789
1/8 - 8.5899
mph - 86.39
1/4 - 13.0880
MPH - 111.09
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
These are brand spankin NEW Toyo Proxe T1R's 245/45/16 :(
had the tire pressure at 22psi
spun pretty good in 1st and 2nd...boo:(
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Are you just outright DUMPING the clutch?
Remember, lanuching hard, you let out of the clutch basically the same as if you were to take off at a stoplight...with the addition of going WOT immediately after the initial takeoff.
-Jeff
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
hell no im not DUmpin the clutch. if i did that i would get like a 2.5 60ft :lol:
im trying as best i can..and i think a 2.0 60 is good for street tires.
but listen...Im just askin..Does the mph go with the ET?
Whats peoples time with a MPH like that?
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
i was messing around with an e/t calculator, just random guessing and this is what i got.
Your ET / MPH computed from your vehicle weight of 3500 pounds and HP of 400 is 12.00 seconds and MPH of 111.62 MPH
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
hmm...that couldnt be more off...I should be around 375rwhp from my tune. and i weigh 155lbs+3600lbs...and everyone knows the supra needs more power than that to get a 12 flat.
Boost Lee
2,750
Indianapolis, IN
Not if you're Auto. ;)
Well, I don't think that your ET & Trap are terribly off. Everything is totally dependant upon your setup.
Which in case, with your 60' times, your trap speeds seem pretty comparable to others.
suprarich
Guest
Nov 9, 2005
2,187
ohio
You are close, but your mph and times are both off. You have a slower start because you can not give it all at the line, or you will spin. This slows down your mph because of your slower start. Your et is also suffering from the slow start. Take your 60' down to a 1.9 or 1.85 and you should see a 12.75-12.80 at 112-113
tissimo
Stock is boring :(
Melbourne, FL
should go faster then that.. i say 12.70s-12.80s with a 2.0 60' like hes doing.. just gotta bang them gears :) if you hear the bov during a shift you shifted too slow :icon_bigg
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
haha...ya i shifted as fast as i felt i should...my tranny is already whining in 1st thru 3rd while driving...but yet, drives fine..maybe i need to check my fluid.
