the posts i have found on code 51 refer to the TPS. can code 51 have anything to do with the regular
02 sensor as when i disconnected it to remove the exhaust it was very dirty from rich fuel and could that disturbance cause the problem. resistance on the 02 sensor was 4.0. TPS resistance was in the correct range without shiming the throttle. problem is that the car starts and idles at 10.5 a/f but when i give it throttle it goes very lean and tries to stall. none of that was happening before wide band installation. thanks steve
