Following the TSRM I secured the steering wheel with a high tension bungee, that thing didnt move a bit once it was in place. I replaced the rack, and before reinstalling, I made sure the match marks on the universal joint and control valve shaft were lined up as best I could (I did the rack replacement with the motor in the car) and connected the intermediate shaft side to the universal joint on the steering column assembly. I took the car for a spin, and in order to drive straight, the wheel has to be turned slightly to the right. So that tells me the control valve shaft/intermediate shaft must have rotated while I was trying to get it connected to the u-joint on the steering column assembly.
So what are my options?
1) Remove the entire rack, secure the steering wheel in the straight position, line up the match marks on the control valve shaft and universal joint again, and figure out a way to restrict the control valve shaft/intermediate shaft from rotating while I reinsert the intermediate shaft into the u-joint on the steering column assembly.
2) Jack the car up, turn the steering wheel until the wheels are straight, loosen bolt on intermediate shaft side and bolt on control valve shaft side, pull out intermediate shaft, straighten steering wheel and secure, reinstall intermediate shaft onto control valve shaft.
3) Jack up car, straighten wheels and secure from moving, remove the steering wheel and straighten it, reinstall.
Of the three, I think that the last one would be the least intensive, mainly because, I wouldnt have to get under the car and mess with the shaft or the rack. My main question is if I could even do that without messing anything up with the spiral cable?
