Ok so I pulled the intake manifold off to replace all the hoses and gaskets to prevent leaks for best performance. So as we were pulling the harness after everything there's a wire that runs down to the transmission that has 2 wires... I couldn't find a connector though? So i cut it to remove the manifold, then resoldered it afterward. But is there a connector for these wires? I almost just want to get 2 female and male connectors so i can just disconnect and reconnect it everytime. I thought this was really weird. Also should the vaccum tree and vsvs be bolted to the upper manifold before reinstallation to the low intake runners? I tested the TPS since it was throwing a code 31.. It was bad. What kind of problems will a bad TPS cause?
