Engine Temp.
suicide
86
Barrie , Canada
HI there i was just wondering if their are some people out there that actually know what temperature their engine is running... i just would like to compare mine to so other people.
thanks....
supramk3man
414
kentucky
About the same unless it is a real hot day in town and ac on then i might see 200-205 but usaly 180-190. that is with a stock raditator and normal fan.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
are you asking what the average coolant temp should be? or the actually block temp? two totally different things
-pete
mkIIIman089
Ohio
Measured ~6 inches post thermostat on the upper rad hose mine runs at ~92C after it's done fluctuating.
8,897
Well, the coolant temp sensor doesn't measure the block temperature, so it must be the coolant.
The engine runs around 200 degrees, as warm as 210 is normal. The thermostat starts to open at 192. Fully open is even warmer. A thermostat maintains minimum temperatures, not average or max.
