Engine Temp.?
ts_MKIII
239
Virginia Beach
Well my Engine temp seems a little faulty short spikes up or down.
I was wondering how to treat this illness.
Thanks.
Also do our motors generate a Pretty good amount of heat. Ive been noticed increased warmth in the cabin near the floor boards and fire wall.
7mgte thanks.
N
NDBoost
Guest
question 1.
It could be either a sign of air getting in the cooling system
or it could be a faulty temp sensor. Check the temp sensor and pressure test your cooling system. Do you get any waterfall noises behind the dash?
question 2.
All i know is my legs used to sweat when i leaned em up against my tranny tunnel while driving in my old 5spd supra, so yeah you could say they generate alot of heat lol..
92turbo4life
1,289
wherever
this is how i tested mine when it goes all the way up pull over and touch the radiator cap. if its warm your gaueg is broke <like mine> if it is hot or accurate with your gauges reading your gauge is fine.
if you can hold your hond on the cap while the gaugeis all the way up the gauge is done. otherwise your hand well get roasted:)
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Or your thermostat is stuck closed and your cooking your engine:dunno:
lagged
1991 1JZ
new rochelle
or youre out of water! your test sucks.
7MGTEsup
Jun 14, 2005
614
England
ts_MKIII said:
well the previous owner said theres a new water pump but i dont know for shure, so how would i put water or check water?
When the engine is cold take off the radiator cap, the coolant level should be level with the bottom of the neck. Check your overflow tank is on the full level (its down by the left headlight infront of the radiator.)
