engine sounds unbalanced
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi guys, When i rev my engine freely at around 3-4k rpm and up the engine almost sounds unbalanced. It has always done this. Kind of like the harmonic balancer isn't perfectly round or something. I'm pretty sure its not rod knock. What do you guys think?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
It could well be that your harmonic balancer is shot, how old is it exactly? The original? I'd say so ;)
The 6M crank you have doesn't help either.
I wonder where the worst harmonic imbalance is at in a 6M 7MGTE supra...
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Try cleaning you're crankshaft pulley or "harmonic balancer" witch it doesn't have. Really its just a dampener. You could have chunks of dirt stuck inside.
If its a 88- then at about 5.5k+ its normal
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
Your crankshaft pully may be loose try to tighten it to 197 ft lbs in 5th gear.
