engine sounds redline at 3-4k rpm help plz
Malkavia
25
orlando
i have a coolant leak and im going to be redoing all the coolant lines and perhaps vacuum as well but when i drove it up to get gas i noticed there is a pretty big coolant leak and the engine sounded like it was redlining at 3-4k rpm i didnt step on it for fear of future problems so i dont know if the power stopped it just got a lot louder then usual also my key in the ignition got practically red hot, think if i fixed the coolant problem these probs should be fixed? ive never had this kind of coolant problem before lol
hellraiser456
130
canada
umm...does it start now?
define a "big coolant leak".....how long did you drive without coolant and how high did the temp gauge get.
Malkavia
25
orlando
temp gauge only got halfway up which is normal but the guy i bought it from said it overheats after like 20 mins and i only drove it like 1/2 mile with the coolant leaking out, i mean theres still a ton left in the tank but im not driving on it til i determine if its the hoses a BHG or both
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
easily overheats? bhg? fan clutch?
Malkavia
25
orlando
im thinkin its a cracked hose because besides the coolant leak and overheating im not seeing any other signs of a BHG but anythings possible with a MKIII the temp gauge has only gone 1/2 way up never higher but i have coolant leaking out so im thinkin i got a busted hose and perhaps the thermostat is messed up ill have to have a friend come over and see because i cant tell i just hope its not a BHG either way ive gota retorque it but if its blown well thats 1-1.5 grand in labor i just dont have
Malkavia
25
orlando
yeah i know the key gets hot and i just ran the engine for 20 minutes and i got pressure in the radiator coolant in the top of the radiator coolant leaking out the bottom and i cleaned off the dipstick and put it back in, now i got milky oil so yeah i got a BHG fun fun fun but at least it happened now and not later when im runnin like 13psi lol
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
but still the ignition cylinder has nothing to do with a bhg. im pretty sure there isnt anything back there that gets hot. its pretty bizarre
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
maybe its just a hot day :) my keys get hot too when the sun shines in..
Malkavia
25
orlando
yeah i know what you mean but a coolant leak, overheating, milky oil, if it sounds like a duck and looks like a duck.....
antman
632
TN
Did you taste it?...
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Taste like spoiled milk :cry: Yeah, working on a budy's car and it's weird, just replaced the headgasket and everything and it still has milky oil.... it's weird :nono:
antman
632
TN
Its going to take quite a few oil and filter changes to get it back right.
