Engine Problems
Supraluva
20
NJ
I recently got my mkii 7mgte running again after redoing the engine bay. The engine has a new engine harness, To4Z turbo, FFIM, 720cc injectors, AFPR, Aeromotive A1000 fuel pump, and is running the MAPECU. Now the engine starts right up and idle solid. It will rev up fine and sounds very strong at idle. However, once you apply load and try to drive the car, the engine will rev to about 2-3k then just let off. If you hold the gas constant at say, 25% throttle, the engine will rev up then just let off like you hit fuel cut, then just rev up again and continue the cycle. There is also no check engine light on. Does anyone have any clue what could be causing this?
As far as the MAPECU, it seems to be working fine. All the readings, such as TPS percentages, RPMs, and A/F ratios seem to be working fine. If you make adjustments to the fuel the A/f ratios do change which leads me to believe that its working ok. Any ideas??
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
check your codes...the light doesn't have to be on. Other than that I have no idea where to start.....hopefully one of the old-school guys can chime in and tell you what you need to look for. Good Luck
Supraluva
20
NJ
I checked for codes and its throwing out 32 which is for the afm. Is this normal for running the MAPECU since it gets rid of the afm or should this code not be thrown out? If not normal why would the ecu throw a code for the afm?
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
code 32 is not normal for the map ecu, i am using it in mine and has never thrown that code, you should check your map ecu wiring again, did you use this? is yours pre 89 ? that is the wiring for the pre 89, seems your stock ecu is not seing the map signal
  • map ecu wiring.pdf
Supraluva
20
NJ
I double checked and triple checked the wiring and its all good. I changed the tps and the car runs under load now. However, the 32 code is still being thrown. COuld it be that my mapecu unit is bad?
Supraluva
20
NJ
Well, tomorrow I'm gunna have the car on the dyno. I've only messed with the idle and the car seems to be idling ok at around 14 a/f. I haven't touched the tps enrichment yet. Do I need to use tps enrichment or is that just to fine tune the idle and partial throttle? I guess I'll triple check the wiring tomorrow before I make any runs on the dyno. I'll update you on what happens tomorrow. Thanks for all your help.
Supraluva
20
NJ
Hmmm... I've never had this in the car as it was never on the swap list when I did the swap years ago. Its it ok if I run without one? How much would it effect my tune?
Jason
