Engine no start
Volvospy
55
Northern VA
I'm having trouble with my 7mgte. I replaced the 550cc (evo injectors) and Lexus afm. Turbo is ct26 62 trim, it's running 9-10 psi. I pushed the car hard one time and the efi 15a fuse was dead afterwards. I replaced the fuse, it started again but it ran very rough like no fuel or spark, and then it shut down. I checked spark plugs, 2 of them were kinda fuel wet, and replaced them all. I also checked all the fuses already. What would be the problem in my case? Thank you!
Volvospy
55
Northern VA
Just checked spark plugs again, they're flooded. Now my starter is bad, I can't test spark. How often does the coil pack go bad? Anyone knows?
Volvospy
55
Northern VA
Thanks guys, I got the damn fuel pump replaced. I upgraded the 550cc and pushed it hard, then the fuel pump died. It has 190k on it already. Btw, if someone wants 550cc installed, should replace fuel pump too if mileage is high.
